davidenco
Mar 25, 2015Aspirant
Have to reboot ReadyNAS to use USB hard disk?
I have connected a Tandberg QuikStor RDX USB3+ hard disk enclosure with 2TB hard disk to my ReadyNAS Duo v2. In order for the RDX to appear as a USB share, I have to reboot the ReadyNAS first. When...
Nhellie
Apr 02, 2015Virtuoso
It might be the size of the HDD that you are using (might be too big). Previous USB HDDs that are compatible to the Duov2 are barely 500GB so I'm thinking the unit might be having a hard time detecting you 2 TB right away without rebooting. My best bet is to contact support so they can report it to thier engineering have them look at your unit.
try the online support:
http://support.netgear.com/general/contact/#tab-email
there is a beta FW, but does not have any related fixes for the issue you are having:
viewtopic.php?f=148&t=72267
