AGTD
Aug 18, 2012Aspirant
HCL-Seagate 3TB ST3000DM001: Is newer p/n:1CH166 included?
According to the Netgear HCL, the 3TB Barracuda 7200.14 ST3000DM001 is compatible with the ReadyNAS Pro4. Caveat is that Firmware CC4H should be used. It appears that the CC4H firmware update is on...
AGTD
Oct 02, 2012Aspirant
After moving a lot of TB around on my PRO4 and lots of data verification, I have not run into any trouble with my 4 ST3000DM001-1CH166 drives. Empirically they appear to be "compatible". It would be great if Netgear could confirm this after running their own tests and assuming that they are "really compatible" adding the drives to the HCL
