AGTD
Aug 18, 2012Aspirant
HCL-Seagate 3TB ST3000DM001: Is newer p/n:1CH166 included?
According to the Netgear HCL, the 3TB Barracuda 7200.14 ST3000DM001 is compatible with the ReadyNAS Pro4. Caveat is that Firmware CC4H should be used. It appears that the CC4H firmware update is on...
devilsrear
Oct 04, 2012Aspirant
I have 2 of these drives in my duo v2 - running firmware version CC43. Not had any issue with these at all.
Disk 1Seagate ST3000DM001-1CH166 2794 GB (29 °C, Write-cache On). Status: OK
Disk 2Seagate ST3000DM001-1CH166 2794 GB (29 °C, Write-cache On). Status: OK
Both been running for 2049 hours - 86 days
