AGTD
Aug 18, 2012Aspirant
HCL-Seagate 3TB ST3000DM001: Is newer p/n:1CH166 included?
According to the Netgear HCL, the 3TB Barracuda 7200.14 ST3000DM001 is compatible with the ReadyNAS Pro4. Caveat is that Firmware CC4H should be used. It appears that the CC4H firmware update is on...
grunnsat
Oct 07, 2012Aspirant
The same problem applies to the 2TB ST2000DM001. The old version has part# 9YN164 and needs firmware revision CC4H, the new version has part# 1CH164 and has firmware revision CC43. This drive is supported in the NV+, but so far I have bricked three brand new drives after just a few days. I would say that the two product lines are different products, and should be separately certified. Can we please have a statement by Netgear on this subject?
