AGTD
Aug 18, 2012Aspirant
HCL-Seagate 3TB ST3000DM001: Is newer p/n:1CH166 included?
According to the Netgear HCL, the 3TB Barracuda 7200.14 ST3000DM001 is compatible with the ReadyNAS Pro4. Caveat is that Firmware CC4H should be used. It appears that the CC4H firmware update is on...
Oct 09, 2012Guru - Experienced User
I think you could challenge that, perhaps Beisser could help. CC4H fixed a particular problem with particular drives, other variants that can't run this firmware shouldn't need that fix, and should be supported.
grunnsat wrote: When I explained the difference between the two ST2000DM001 versions to Netgear support, and also stated that it was not possible to load the recommended CC4H firmware in my disks, then they told me that the disks were not supported because the recommended firmware can not be loaded.
