AGTD
Aug 18, 2012Aspirant
HCL-Seagate 3TB ST3000DM001: Is newer p/n:1CH166 included?
According to the Netgear HCL, the 3TB Barracuda 7200.14 ST3000DM001 is compatible with the ReadyNAS Pro4. Caveat is that Firmware CC4H should be used. It appears that the CC4H firmware update is on...
grunnsat
Oct 12, 2012Aspirant
The point is that the other variant(s) have not been tested and certified. Seagate uses the same commercial names (STn000DM001) for two different lines of products. The two lines can be distinguished by their different part numbers. We don't know the differences between both product lines. IN my opinion only the drives with part numbers starting with 9YN have been certified.
