AGTD
Aug 18, 2012Aspirant
HCL-Seagate 3TB ST3000DM001: Is newer p/n:1CH166 included?
According to the Netgear HCL, the 3TB Barracuda 7200.14 ST3000DM001 is compatible with the ReadyNAS Pro4. Caveat is that Firmware CC4H should be used. It appears that the CC4H firmware update is on...
Oct 12, 2012Guru - Experienced User
The HCL doesn't say that, it simply lists the drive models with no caveats at all.
grunnsat wrote: ...In my opinion only the drives with part numbers starting with 9YN have been certified.
The statement on the HCL is: WARNING: Be sure to use only drives recommended in the compatibility list, otherwise, NETGEAR Technical Support can and will deny support.
Your drive is listed, as far as I can see you are entitled to support.
