AGTD
Aug 18, 2012Aspirant
HCL-Seagate 3TB ST3000DM001: Is newer p/n:1CH166 included?
According to the Netgear HCL, the 3TB Barracuda 7200.14 ST3000DM001 is compatible with the ReadyNAS Pro4. Caveat is that Firmware CC4H should be used. It appears that the CC4H firmware update is on...
mdgm-ntgr
Oct 17, 2012NETGEAR Employee Retired
1. I think this is automatically enabled if you have a UPS connected. Otherwise it would be disabled.
2. As AGTD said you'd go to Status > Health in Frontview.
