AGTD
Aug 18, 2012Aspirant
HCL-Seagate 3TB ST3000DM001: Is newer p/n:1CH166 included?
According to the Netgear HCL, the 3TB Barracuda 7200.14 ST3000DM001 is compatible with the ReadyNAS Pro4. Caveat is that Firmware CC4H should be used. It appears that the CC4H firmware update is on...
cambridgebandb
Oct 29, 2012Aspirant
refles wrote: hi guys, I just ran into the same problem w/ my Pro6, I already had 2 ST3000DM001's in place added 2 more a week ago with the firmware CC4H and I got an additional 2 more drives from Amazon this week but they came in with CC43 fimware (p/n 1CH166-300). I emailed Seagate a few moments before and they only responded back with the following link
https://apps1.seagate.com/downloads/request.html
I don't have any of the serials of my CC4H drives handy currently as I'm at work, but I threw in the 2 serials from Amazon that had the CC43 firmware and said "No New Firmware Available" ... if someone would throw their CC4H serial in maybe it'll say whether or not CC43 is the newer version via their DB records. Maybe that will tell us if its definitely newer, but obviously if it works or not official word hasn't been given, but the few that reported here that they've been using it already in smaller setups appears encouraging as I would hate to have failure due to a such a change.
if no one gets a chance I'll report back my findings tonight when I get a chance to throw my serial in.
I just tried with my ST2000 drive and it says the firmware I have (which is CC43 according to the label on the drive) is the latest.
