AGTD
Aug 18, 2012Aspirant
HCL-Seagate 3TB ST3000DM001: Is newer p/n:1CH166 included?
According to the Netgear HCL, the 3TB Barracuda 7200.14 ST3000DM001 is compatible with the ReadyNAS Pro4. Caveat is that Firmware CC4H should be used. It appears that the CC4H firmware update is on...
tin008
Nov 25, 2012Aspirant
I am the same as you. Got the drives from Amazon, but I got the NV+ 2 Nas.
I just put 2 of those 1CH166-300 in it. It seems ok. I setup them up for less than 12 hours, so far so good.
