AGTD
Aug 18, 2012Aspirant
HCL-Seagate 3TB ST3000DM001: Is newer p/n:1CH166 included?
According to the Netgear HCL, the 3TB Barracuda 7200.14 ST3000DM001 is compatible with the ReadyNAS Pro4. Caveat is that Firmware CC4H should be used. It appears that the CC4H firmware update is on...
refles
Nov 30, 2012Aspirant
Been so busy I didn't get a follow up reply, but for the record in case anyone is interested or if the problem hasn't been directly answered. I've run the new FW on the 2 Seagates w CC43 (in parallel with the older FW CC4H, qty 4) for about what SMART is reporting 1020 hrs and migrating my data slowly over as i build confidence with the drives and its working fine. There's not been any errors of any sort. So mixing the 2 FW's don't seem to be an issue on the drive or the device itself.
