boblam
May 03, 2012Aspirant
HCL X6 - Disk Drives
I have an X6 and one of the disks is failing. It doesn't appear that the HCL lists drives for the X6 (RAIDiator 4.1.7). I stayed on that version of RAIDiator as the newer version caused performance ...
mdgm-ntgr
May 03, 2012NETGEAR Employee Retired
The Infrant ReadyNAS X6 is a Sparc ReadyNAS. It was discontinued prior to the NetGear acquisition. Please use drives from the compatibility list for the NV+ (v1) which is also a Sparc ReadyNAS.
I would not recommend the ST2000DL003 drive at this time. There is a known issue with that drive that is addressed by a test firmware released by SeaGate.
