ardea
Jun 09, 2017Aspirant
HD Compatibility Question
We have 2 NV+ presently each filled with 4 x 750 GB Seagates . We need to upgrade to the maximum 4 x 2TB. Their HCL contains many unobtainable disks. This post:
suggests that the WD20EFRX not only works OK, but "quacking plums" says he found it at last on the HCL - but as far as I can see it's only listed for the NV+ v2
Does the Community maintain an up to date HCL, or have a current suggestion for 2TB? Buy the WD20EFRX?
Thanks in anticipation,
ardea
- SandsharkSensei
Yes, the WD Reds up to 2TB are an excellent choice for the NV+.
Unfortunately Netgear stopped adding to the HCL for the legacy ReadyNAS quite a while ago.
I also recommend the WD20EFRX in these NAS. I have one in my Duo v1, and it works well.
- JBDragon1Virtuoso
WD Red drives are a great choice. Swap out 1 drive at a time and let the NAS rebuild the system first, then pop in a second new drive, rebuild, then a 3rd, and finally a forth. That way you won't lose any data. As long as it's setup as XRAID5. You can even access the NAS as it's rebuilding, though it'll be faster if it's just left alone to do it's thing. It'll still take some time for each drive. At least they're small drives.
I actually have 4 3TB WD Red drives that used to be in a NV+ V2 before being pulled and installed in a 516. They still work great and a couple are in the 4 year old range now. Jumping from 750 GB to 2TB drives will be nice update. Going from 2.03 TB of space to 5.43 TB. That's more then double, and 2TB WD Red drives are pretty cheap now.
You're getting your money's worth out of them OLD NAS units.
JBDragon1 wrote:
Swap out 1 drive at a time and let the NAS rebuild the system first, then pop in a second new drive, rebuild, then a 3rd...
I do suggest upgrading to the current firmware before you begin (4.1.16).
Also, since your NAS is old, it might be wise to do a factory reset instead of replacing one drive at a time. You would need to restore data from a backup of course. There are a couple of special circumstances with older V1s, where a factory reset is the best approach. One is if your data volume doesn't have 4K sector alignment. Also, there was an volume size limit long ago, which required a factory reset to overcome (related to RAID block size I think)
mdgm-ntgr used to have a guide here: http://www.rnasguide.com/2011/06/22/why-you-might-want-to-factory-reset-a-sparc-readynas/ But www.rnasguide.com doesn't seem to be hosted anymore.
- JBDragon1Virtuoso
Sometimes there's good reasons to start fresh. I ended up doing that on my NAS and I didn't even change HDD's. At least there's not a lot of Data to Backup and restore so it shouldn't take all that long to just start fresh.
