enbeekay
Feb 15, 2014Aspirant
HDD issue.
Hi. I've had an issue with an HDD in a ReadyNAS NV+ v2. I've got messages saying a drive had failed and the system had shut down. The system is populated with 4x3TB Seagate HDD's. Due to this i ...
vandermerwe
Feb 15, 2014Master
What firmware are you on?
Did you run an extended or long test with seatools? The short test will miss errors.
I would make sure you have a backup, then insert the new wd drive after making sure you check the idle setting and adjusting it if necessary.
