rjdk2010
Jan 22, 2013Aspirant
Help please :)
Hello all, just want to know what readynas unit i will need for my requirements. My gear that I already have: Netgear wnr2200 wireless router - http://www.netgear.com.au/home/products/wireles...
mdgm-ntgr
Jan 22, 2013NETGEAR Employee Retired
With the RND2000 if the video isn't exactly in the correct format to play on your devices you won't be able to play it on your iPhones. The RNDU2000 would enable a greater range of media to be playable on your iPhones.
