s1m0n27
May 26, 2012Aspirant
Help readynas duo v2 setup problems
ok guys hope somone can help. I purchased a readynas duo v2 with no hdds :) anyways after finally finding out that i needed a factory reset to get the thing to boot and install hdds i seem to be ha...
s1m0n27
May 28, 2012Aspirant
evan wrote: "i first load into the dash it says "dashboard 1.0.0.224" but when i click on configure is says dashboard version 1.0.0.168R", please clear your browser's cache, you dashboard should be 1.0.0.224, it is latest version.
many thanks that has solved that problem :)
both drives now show up and i have now set share folders so i can network map correctly to my computer and NFS share and DLNAshare with other devices :)
I seem to be getting good speeds :) a steady 40MBs , Highs of 44MBs , and the odd low of 39MBs :), way better than the sharecentere I had to send back because of the attrocious speeds.
Anyway thanks for the help its much appreciated :)
