Farnorthsurfer
Mar 27, 2012Aspirant
Help with Dead Duo V1 please?
My old faithfull ReadyNAS Duo appears to have died and has taken much of my data with it.. It began making a noise like a disc winding up then beeping over and over again. The start switch light is p...
mdgm-ntgr
Mar 27, 2012NETGEAR Employee Retired
Ah I see you've tried data recovery using a Windows machine already. Have you been able to test the disks using vendor tools?
What RAID configuration were you using? The default X-RAID or something else?
With the 3 year warranty voided there's probably not much if anything NetGear support would be able to do to help.
