Farnorthsurfer
Mar 27, 2012Aspirant
Help with Dead Duo V1 please?
My old faithfull ReadyNAS Duo appears to have died and has taken much of my data with it.. It began making a noise like a disc winding up then beeping over and over again. The start switch light is p...
Farnorthsurfer
May 26, 2012Aspirant
Hi Chirpa
PM sent
Surprised to see that when I tested the faulty PSU the volts were 12.81v which I would think is in tolerance.
The Fluke gave a figure of 9.58 amps output which is high but I am not sure it is a very relevant measurement.
So the fault in the PSU remains unresolved but the Duo has been working with the Channel Well unit for over 48 hours.
Very happy to have my data back.
With regard to unit failures would Netgear possibly consider publishing a small recovery program for Windows PC's that would allow RAID-X files to be saved.
That would have saved me a lot of trouble.
Thanks
Mark
PM sent
Thanks
Mark
