toms1's avatar
toms1
HGST 4 TB Deskstar 7K4000 in ReadyNAS Pro 6
I know these drives are drives are not on the HCL but does anyone have experience running them successfully in a Pro 6 unit? Or any ReadyNAS unit for that matter? The prices have dropped pretty significantly and are almost on par with the 3TB version. I'm looking at the Deskstar 7200RPM version, which is the 3 year warranty consumer grade drive, with RVS but lacking the "enhanced" RVS of the enterprise class Ultrastar drives. Any thoughts on this?
Thanks!
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    While not officially supported users have found 4TB drives to work find for them. YMMV. If you do choose to use unsupported disks it is especially important that you make sure that your backup of important data primarily stored on the NAS is up to date.
    Also note a few expansion limitations.
    1. Online expansion is limited to 8TB over the life of the volume. If your volume was 5.4TB in capacity when you last did a factory default you cannot expand past 13.4TB.
    2. Expansion past 16TB is not possible. You would need to factory default with the drives in place. This limitation shouldn't be an issue unless you intend to use X-RAID2 single-redundancy (definitely not recommended if using 6x 4TB disks).
  • Fwiw b&h photo has the 7k4000 on sale for $189 right now.
  • Thanks, I had been waiting for the seagate external 4gbs to drop below 200 again, but this should do nicely!
  • fyi, installed 4 of 6 disks (dual redundancy)
    Ch 1 : Hitachi HDS724040ALE640 [3726 GB]
    3721 GB allocated
    Ch 2 : Hitachi HDS724040ALE640 [3726 GB]
    3721 GB allocated
    Ch 3 : Hitachi HDS724040ALE640 [3726 GB]
    3721 GB allocated
    Ch 4 : Hitachi HDS724040ALE640 [3726 GB]
    3721 GB allocated
    Ch 5 : SAMSUNG HD204UI [1863 GB]
    1858 GB allocated
    Ch 6 : SAMSUNG HD204UI [1863 GB]
    1858 GB allocated
    they run about 10c higher than the samsungs that they replaced
    Disk 1 Hitachi HDS724040ALE640 3726 GB , 43 C / 109 F , Write-cache ON OK
    Disk 2 Hitachi HDS724040ALE640 3726 GB , 44 C / 111 F , Write-cache ON OK
    Disk 3 Hitachi HDS724040ALE640 3726 GB , 43 C / 109 F , Write-cache ON OK
    Disk 4 Hitachi HDS724040ALE640 3726 GB , 40 C / 104 F , Write-cache ON OK
    Disk 5 SAMSUNG HD204UI 1863 GB , 35 C / 95 F , Write-cache ON OK
    Disk 6 SAMSUNG HD204UI 1863 GB , 33 C / 91 F , Write-cache ON
    sauron:~# df
    Filesystem 1K-blocks Used Available Use% Mounted on
    /dev/md0 4184756 2235712 1739384 57% /
    tmpfs 16 0 16 0% /USB
    /dev/c/c 11645104480 8729122960 2915981520 75% /c
    /c/backup 11645104480 8729122960 2915981520 75% /home/ftp/backup
    /c/media 11645104480 8729122960 2915981520 75% /home/ftp/media
    tmpfs 51200 0 51200 0% /var/replicate/shm
    sauron:~# df -h
    Filesystem Size Used Avail Use% Mounted on
    /dev/md0 4.0G 2.2G 1.7G 57% /
    tmpfs 16K 0 16K 0% /USB
    /dev/c/c 11T 8.2T 2.8T 75% /c
    /c/backup 11T 8.2T 2.8T 75% /home/ftp/backup
    /c/media 11T 8.2T 2.8T 75% /home/ftp/media
    tmpfs 50M 0 50M 0% /var/replicate/shm
    expansion log, note had to reboot after the first disk replacement for to start the resync/rebuild on the new disk.
    Sat Dec 1 13:09:56 CST 2012 RAID sync finished on volume C.
    Sat Dec 1 02:22:20 CST 2012 Data volume has been successfully expanded to 11105 GB.
    Sat Dec 1 02:22:19 CST 2012 System is up.
    Sat Dec 1 02:22:02 CST 2012 Continuing with volume expansion or migration. Do not interrupt the system during this time. When complete, email notification will be sent to the alert contact list.
    Sat Dec 1 02:20:12 CST 2012 System is up.
    Sat Dec 1 02:17:25 CST 2012 Powering off device
    Sat Dec 1 02:17:25 CST 2012 Please close this browser session and use RAIDar to reconnect to the device after it is powered back on. System powering off...
    Sat Dec 1 02:14:03 CST 2012 Found space that can be used to expand capacity, expansion process will start during next boot.
    Sat Dec 1 02:13:57 CST 2012 Found space that can be used to expand capacity, expansion process will start during next boot.
    Sat Dec 1 02:13:06 CST 2012 Found space that can be used to expand capacity, expansion process will start during next boot.
    Sat Dec 1 02:12:59 CST 2012 RAID sync finished on volume C.
    Fri Nov 30 18:58:37 CST 2012 RAID sync started on volume C.
    Fri Nov 30 18:57:49 CST 2012 Data volume will be rebuilt with disk 4.
    Fri Nov 30 18:56:37 CST 2012 New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 4]
    Fri Nov 30 18:54:36 CST 2012 If the failed disk is used in a RAID level 1, 5, or X-RAID volume, please note that volume is now unprotected, and an additional disk failure may render that volume dead. If this disk is a part of a RAID 6 volume, your volume is still protected if this is your first failure. A 2nd disk failure will make your volume unprotected. If this disk is a part of a RAID 10 volume,your volume is still protected if more than half of the disks alive. But another failure of disks been marked may render that volume dead. It is recommended that you replace the failed disk as soon as possible to maintain optimal protection of your volume.
    Fri Nov 30 18:54:36 CST 2012 Disk failure detected.
    Fri Nov 30 18:54:17 CST 2012 A disk was removed from the ReadyNAS. For full protection of your data volume, please add a replacement disk as soon as possible.
    Fri Nov 30 18:54:17 CST 2012 Disk removal detected. [Disk 4]
    Fri Nov 30 14:45:42 CST 2012 RAID sync finished on volume C.
    Fri Nov 30 08:24:23 CST 2012 Subsonic service has been started.
    Fri Nov 30 07:28:22 CST 2012 RAID sync started on volume C.
    Fri Nov 30 07:28:03 CST 2012 Data volume will be rebuilt with disk 3.
    Fri Nov 30 07:26:51 CST 2012 New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 3]
    Fri Nov 30 07:23:54 CST 2012 If the failed disk is used in a RAID level 1, 5, or X-RAID volume, please note that volume is now unprotected, and an additional disk failure may render that volume dead. If this disk is a part of a RAID 6 volume, your volume is still protected if this is your first failure. A 2nd disk failure will make your volume unprotected. If this disk is a part of a RAID 10 volume,your volume is still protected if more than half of the disks alive. But another failure of disks been marked may render that volume dead. It is recommended that you replace the failed disk as soon as possible to maintain optimal protection of your volume.
    Fri Nov 30 07:23:54 CST 2012 Disk failure detected.
    Fri Nov 30 07:23:53 CST 2012 A disk was removed from the ReadyNAS. For full protection of your data volume, please add a replacement disk as soon as possible.
    Fri Nov 30 07:23:53 CST 2012 Disk removal detected. [Disk 3]
    Fri Nov 30 02:08:09 CST 2012 RAID sync finished on volume C.
    Thu Nov 29 18:56:53 CST 2012 RAID sync started on volume C.
    Thu Nov 29 18:56:36 CST 2012 Data volume will be rebuilt with disk 2.
    Thu Nov 29 18:55:25 CST 2012 New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 2]
    Thu Nov 29 18:52:45 CST 2012 If the failed disk is used in a RAID level 1, 5, or X-RAID volume, please note that volume is now unprotected, and an additional disk failure may render that volume dead. If this disk is a part of a RAID 6 volume, your volume is still protected if this is your first failure. A 2nd disk failure will make your volume unprotected. If this disk is a part of a RAID 10 volume,your volume is still protected if more than half of the disks alive. But another failure of disks been marked may render that volume dead. It is recommended that you replace the failed disk as soon as possible to maintain optimal protection of your volume.
    Thu Nov 29 18:52:45 CST 2012 Disk failure detected.
    Thu Nov 29 18:52:19 CST 2012 A disk was removed from the ReadyNAS. For full protection of your data volume, please add a replacement disk as soon as possible.
    Thu Nov 29 18:52:19 CST 2012 Disk removal detected. [Disk 2]
    Thu Nov 29 10:30:00 CST 2012 RAID sync finished on volume C.
    Wed Nov 28 20:25:44 CST 2012 System is up.
    Wed Nov 28 20:23:11 CST 2012 Rebooting device...
    Wed Nov 28 20:23:11 CST 2012 Please close this browser session and use RAIDar to reconnect to the device. System rebooting...
    Wed Nov 28 20:01:30 CST 2012 Data volume will be rebuilt with disk 1.
    Wed Nov 28 20:00:17 CST 2012 New disk detected. If multiple disks have been added, they will be processed one at a time. Please do not remove any added disk(s) during this time. [Disk 1]
    Wed Nov 28 19:57:24 CST 2012 If the failed disk is used in a RAID level 1, 5, or X-RAID volume, please note that volume is now unprotected, and an additional disk failure may render that volume dead. If this disk is a part of a RAID 6 volume, your volume is still protected if this is your first failure. A 2nd disk failure will make your volume unprotected. If this disk is a part of a RAID 10 volume,your volume is still protected if more than half of the disks alive. But another failure of disks been marked may render that volume dead. It is recommended that you replace the failed disk as soon as possible to maintain optimal protection of your volume.
    Wed Nov 28 19:57:24 CST 2012 Disk failure detected.
    Wed Nov 28 19:56:54 CST 2012 A disk was removed from the ReadyNAS. For full protection of your data volume, please add a replacement disk as soon as possible.
    Wed Nov 28 19:56:53 CST 2012 Disk removal detected. [Disk 1]
ProSupport for Business
