DjamesB
Jan 09, 2013Aspirant
High Pro 2 CPU Temperatures/Fan speed not steady
Hi folks, my IT guys have been buying lots of Duos over the past couple of years for file storage for my offices and I decided to get 2 - Pro 2's for my home, one for a HomeServer to share, and one fo...
DjamesB
Jan 11, 2013Aspirant
Ya, that's what I was thinking too. Took them both out, put them in win8 machine I have and there is no ticking and read the disks just fine. The ticking is ONLY when both disks are in the Pro 2. When either drive is in alone, either bay 1 or 2, there is no ticking. Some kind of controller read issue, in my very limited knowledge... I just pulled them both out, put them in a win8 pc, and removed all of the partitions. No "ticking" as they spin up in the PC. May not get to this as have to run to work. Thanks for your continued input!
