viperhansa
Oct 20, 2012Virtuoso
High system temperature. ?
I got: Modell: ReadyNAS Pro Business Edition [X-RAID2] Serie: xxxxxxx Fast programvara: RAIDiator 4.2.22 Minne: 4096 MB [4-5-5-18 DDR2] IPv4-adress: 1: 192.168.1.199 IPv4-adress: 2: Inte...
Etz
Oct 20, 2012Aspirant
mdgm wrote: I don't think that there's the option to make such a change.
Actually there is, but I wouldnt recommend it, as it involves tinkering with /frontview/bin/setup_sensors which is used to create /ramfs/enclosure.cfg
Definately "best way" to brick your unit completely, if you mess that up. Also it isnt usual "plain txt" file so its really easy to screw that completely up.
And I also believe that, changing anything in it definately denies anykind of support and probably voids warranty also...
As a side note, for PC`s and electronics, there is always better to find a root cause of high temperatuers then just cranking up the fans. ;)
