MaheshReddy
Aug 26, 2020Aspirant
Home Folder not shared
when i access home folder which is showing you donot have permissions.In Netgear Storgae , Home folder is showing not shared but we have enabled SMB, AFP .Please help us..
1 Reply
If you are talking about /data/home, then that is not shared by design. If you want to browse that specific folder with file explorer or finder, then you need to use the NAS admin credentials.
If you are talking about about a user's private folder, then you should see a share that matches the username when you access the NAS using that user's credentials. That private folder is actually in /data/home, but it is not presented that way to the user.
