cpu8088's avatar
cpu8088
Virtuoso
Sep 09, 2015
Home Folders (special) what is it?
just wonder whats the use of this home folders
can i have it hidden or deleted?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    You can disable them.
    Each user gets their own private home folder that only they and the admin user can access.
    The private home folder is created when the user logs into SMB for the first time. They may need to logut and login again to see the newly created share.
    • cpu8088's avatar
      cpu8088
      Virtuoso
      thanks
      but can it be deleted? or hidden?
        mdgm-ntgr
        If you disable the private home shares then no more private home shares will be created and users won't be able to use them.
        The entry on the web admin page. The web admin page is intended for administration.
ProSupport for Business
