Helpdesk-Kerry
Feb 04, 2016Aspirant
How do I interface with my RND4000?
I am a replacement IT here. I have almost no notes to work from and I have never used a NAS. How do I interface with my RND4000? I tried putting the IP in a web browser and get "Unable to connect". ...
- Feb 04, 2016
Hello Helpdesk-Kerry,
Then it should be accessible. Maybe, try another computer if after reboot it doesn't still open?
Helpdesk-Kerry
The other 2 buttons on RAIDar work fine.
The browse button opens an instance of windows explorer to what appears to be the root of all the shares or folders. Exactly the same as when I was putting \\mynas1\folder1\folder... into the address field of windows explorer.
The locate button blinks the LEDs as expected.otherwise the four LEDs are on steady.
Maybe she needs a reboot... That would have to wait for the weekend.
JennC
Feb 04, 2016NETGEAR Employee Retired
- Helpdesk-KerryFeb 04, 2016Aspirant
Thank you for all your help Jenn. I really appreciate it.
I already tried accessing the Admin Page from another computer by putting the IP address in IE. it didn't open up from there either. Let's hope this weekend tells the tale. I have to upgrade a couple of switches and clean up wiring Sunday. Yay.
