Byrjall
Aug 24, 2022Aspirant
How do I reset my ReadyNAS DUO v1 admin password
Changed my computer and cant accesss the admin page. RAIDar 6.5.0 FW 4.1.14 displays good health. Win 10, ReadyNAS DUO v1 My computer displays but cant login to admin page. Default login is "admin...
Sandshark
Aug 24, 2022Sensei
The default password on a Duo V1 is netgear1 and you must use user name admin. If you still can't get in, an OS re-install will reset them. See here for instructions: How-do-I-access-the-boot-menu-on-my-ReadyNAS-Duo-NV-NV-X6-or-600 . Don't accidently do a factory default, as that will wipe your data.
Byrjall
Aug 30, 2022Aspirant
Thanks for the tip. Still wont let me in.
Error on browser, both Edge and Chrome
192.168.0.199 bruker en protokoll som ikke støttes.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
Any idea why I cant login to admin?
FW is off also.
- StephenBAug 30, 2022Guru - Experienced User
Byrjall wrote:Error on browser, both Edge and Chrome
ERR_SSL_VERSION_OR_CIPHER_MISMATCHAny idea why I cant login to admin?The NAS only supports TLS 1.0. Browsers began deprecating TLS 1.0 a couple months ago.
Internet Explorer will still connect, as will Edge in IE mode. You can also download an older version of FireFox (94.0.2 will connect).
More information on this is here:
- ByrjallOct 27, 2022Aspirant
Hey
I have reset the Nas and use Firefox, but still cant get in?
Any suggestions?
- StephenBOct 27, 2022Guru - Experienced User
Byrjall wrote:
Hey
Any suggestions?
Current FireFox won't connect. Are you using 94.0.2 (or some other older version)?
Are you seeing the SSL protocol error? Or are you getting to the user/password popup?
