rjacobsen
Feb 14, 2024Tutor
How do I update Plex on 6.10.10 Firmware RN516?
Yes I searched the forums, today my Admin page said there was an update to 6.10.10 now the Apps upload is broken "App installation is no longer supported with App Upload or Available Apps." WTF! I'm...
Feb 15, 2024Guru - Experienced User
JBDragon1 wrote:
How do I go back to the last firmware?
You can manually download it from here:
Then install it from system->settings->update (click on install firmware on the right)
JBDragon1
Feb 15, 2024Virtuoso
I got the firmware fixed, but it completely screwed up my NAS. It uninstalled DOCKER and so my Docker apps no longer are running and trying to install Docker fails!!! I am so mad. I've lost so much data because of Netgear!!! Completly uncalled for. I don't know what to do at this point.
My Desktop PC is older that my NAS and still works great. My NAS was working just fine before Netgear screwed it all up. I am just so pissed!!!
- StephenBFeb 16, 2024Guru - Experienced User
Do you mean you downgraded to 6.10.9? If not, I suggest doing that next. After that, re-apply the apt config changes that are documented here:
See post 37, it has links to the files you need to change.
- JBDragon1Feb 16, 2024Virtuoso
Ok after downgrading the firmware to 6.10.9. I went to the link to pointed out and message 37. Then I edited the created the files needed easily using the Windows app "WinSCP". It makes things a snap. Docker CLI was then able to install once again.
Though my Docker apps were not running and I guess those containers gone? I was able to pull updated versions, and create the containers once again and all my settings were still there. I'm once again back up and running. I got those 4 docker apps running once again.
I'm thinking about running all this stuff on a Mac Mini M1. 4 Low power and 4 high power CPU's and a good GPU. I'm hearing some good things for 4K transcoding. So I may end up going that route.
Still, a firmware update should specifically warn you that it is no longer allowing you to install any new apps and in fact is automatically uninstalling software. Why is that? First off, this shouldn't happen in the first place. Let alone no clear big box WARNING on what is going to happen installing this firmware.
It's firmware to make your ReadyNAS almost worthless. What is next for 6.10.11. firmware? Deleting all your files and locking you out completely? At least we have some help here to fix things. That is a big PLUS. But it should never have been done in the first place.
