rjacobsen
Feb 14, 2024Tutor
How do I update Plex on 6.10.10 Firmware RN516?
Yes I searched the forums, today my Admin page said there was an update to 6.10.10 now the Apps upload is broken "App installation is no longer supported with App Upload or Available Apps." WTF! I'm...
mawcasa
Feb 18, 2024Tutor
Hi,
Updates are a process to fix problems, not to kill a product line. If there's not a easy/quick fix to this problem, it will be a 10k problem to replace 2 x RN516. Maybe a lawsuit or maybe common sense will prevail! Or dose anyone have another fix to issue. Thanks
Feb 19, 2024Guru - Experienced User
mawcasa wrote:
Or does anyone have another fix to issue. Thanks
It should be possible to restore the working apt config from 6.10.9 (and then just use ssh to install packages.
Netgear appears to have removed https://apps.readynas.com/ (though it might just be a temporary down server issue)
FWIW, I think it was good to fully remove readycloud from the NAS firmware. But I'd rather they'd left the apps alone (as they have so far with 4.x and 5.x add-ons).
