hicks774
Aug 22, 2014Aspirant
How does mirroring work between two non-empty disks?
I have a ReadyNAS unit in mirroring mode with two disks that were purchased new (empty): DISK0 and DISK1. I want to have an off-site protection in a bank safe: ideally I would like to purchase a 3rd d...
vandermerwe
Aug 22, 2014Master
Of course we don't know what your data consists of, but I agree with TeknoJnky that you should not adopt this as your backup strategy:
1. Your backup is difficult to read, other than in a readynas system.
2. The sata connectors are not built for repeated disconnection/ connection cycles, this may in theory shorten the life of the disks, as may the repeated volume rebuilds that are going to be required.
3. Your backup is potentially 1 month old when you need it - this may be ok for you of course.
4 Your backup is offsite, will you have an onsite backup for easier access?
If you can adopt the USB disk strategy suggested by TeknoJnky this would be better for an offsite backup, albeit requiring a 4th disk. You should consider if possible having an onsite backup.
