dchsueh
May 16, 2013Aspirant
how does the EDA500 work? and safety from disk failures
Hello, I'm wondering how the EDA500 works. Does it simply provide more bays as if they were incorporated in the base unit chassis, or can you have an additional protected set of disks? (for examp...
mdgm-ntgr
May 16, 2013NETGEAR Employee Retired
You would have a separate volume on the EDA500 e.g. so you could backup the data in the main unit via backup job(s)
