iProb8
Jun 24, 2011Guide
How much does a drives RPM make a difference?
I have two ReadyNAS NV+ units that I use in a home environment. One of the NV+ units is used to back up some (but not all) of the data from the primary NV+ unit. I have 5 Macs, two AppleTVs, two TiV...
dbott67
Jun 24, 2011Guide
PapaBear wrote: the Samsung HD204UI drives are not on the HCL. Neither are the Hitachi HDS723020BLA642 drives, although the older HDS722020ALA330 are.
You're correct, PapaBear --- I should have prefaced my comment that they are not on the HCL. I chose them based upon feedback from other forum members and have not had any issues in the month or so that I've used them.
