sweethook's avatar
sweethook
difference between the 1xx- and 3xx-series?
When comparing the "Easy Smart Managed" product data sheets (across various port quantities), I'm finding it very hard to understand the difference between the 1xx- and 3xx-series units, e.g. GS116EP vs. GS316EP. The specs appear identical -- is one unit a newer model, or do they offer different warranties, or something else that's not obvious apart from the visual appearance?
There are elevated price points between the 1xx- and 3xx-series which suggests a delta in spec and/or value proposition. Thank you!
  • The differences between the Easy Smart Managed (1xx) vs. the Easy Smart Managed Essentials (3xx) are made based on different distribution or retail channels, the product warranty terms as you already discovered. Neither Limited lifetime nor a three year warrant can't come for free, but makes an obvious difference in the product calculation.
  • schumaku's avatar
    schumaku
ProSupport for Business
