iProb8
Jun 24, 2011Guide
How much does a drives RPM make a difference?
I have two ReadyNAS NV+ units that I use in a home environment. One of the NV+ units is used to back up some (but not all) of the data from the primary NV+ unit. I have 5 Macs, two AppleTVs, two TiV...
PapaBear1
Jun 24, 2011Apprentice
Plus the fact that if you have problems, you are unlikely to need much help from technical support.
