iProb8
Jun 24, 2011Guide
How much does a drives RPM make a difference?
I have two ReadyNAS NV+ units that I use in a home environment. One of the NV+ units is used to back up some (but not all) of the data from the primary NV+ unit. I have 5 Macs, two AppleTVs, two TiV...
iProb8
Aug 17, 2011Guide
Bad timing on my part, I guess. Makes me wish I had pulled the trigger back in June. :-(
Am I correct that the only difference between the Ultra and the Ultra Plus is that the Plus has a dual core processor? Assuming I'm correct, how much difference does the dual core process make in real life? Is it enough to justify the nearly $100 price differential?
