tigerten's avatar
tigerten
Luminary
Jul 01, 2023
How to backup desktop drive now that readycloud is gone?
Does any know of a way to back up desktop drive using Rsync or similar?
  • StephenB's avatar
    Rsync is more of a linux utility.
    One option you might look at is FreeFileSync.
    It would let you do incremental backups of the PC files to the NAS - either manually or on a schedule.  It can even wake up the PC to do the backup if you want.
    Microsoft has a built-in utility called robocopy that you could also use.  But it requires using the command line - so you'd either create a script for it if you go that route, or find a GUI that uses it.
    • tigerten's avatar
      tigerten
      Luminary
      Thanks StephenB Steph as always. the forum is so fortunate to have you and Sandshark keeing the legend going
      Will give that a try.
      There is cwRsync server which was discontinued and can still be found. Not sure How i can turn my PC into a Rsync server and back it up to Readynas.
      • StephenB's avatar
        What you'd want is the PC to be an rsync client (since the NAS is the destination).
        Personally I use Acronis TrueImage to make image backups of my PCs weekly to the NAS.  That allows me to completely recover the PC (data and OS) if needed.  That's not free though.
        I also have some robocopy scripts that I run on some PCs.
ProSupport for Business
