ZeroGravityWeb's avatar
Aug 20, 2015
How to create a user with admin rights to a share
I have a ReadyNAS 104 that is storing recordings for Axis Camera Station. Apparently I need a user with admin rights to the share (not just read/write) for it to be able to delete old recordings. I can see screenshots in the documentation showing a user assigned to an admin group but I cannot see a way to do that in the NAS admin area. I tried creating an Admin group but was told it already exists. The share is now full of old undeleted recordings and creating issues with the system.
What am I doing wrong or what am I missing.
Many Thanks!
  • If you make the user the owner of the share and of course ensure that the owner has full rights, that should do it.
    What issues are you facing?
    • ZeroGravityWeb's avatar
      ZeroGravityWeb
      It is confusing me. The axis system indicates there is storage outside the system that is taking up space. The only data on the drive is the Axis video recordings. The Axis system is set to delete old recordings after 15 days. There are recordings back to March still on the share. It appears that old recordings are not being deleted. If this was the totally the case then the drive would quickly fill up and remain full but the system keeps recording which indicates that something must be being deleted somewhere. Hence my confusion.
      I changed the settings as you indicated.
      • I have created a user via ReadyNas with the same user name (J-PC) and password from the windows 7 PC that has the Axis recording service running.
      • I created a group "Axis" and assigned this to be the primary group of the user (J-PC)
      • I went to the settings for the share. SMB is the only protocol I have enabled.
      • Under Network Access I have: Everyone: RO; admin R/W; Axis: R/W; users: no setting; J-PC: R/W; Allow anonymous access checked.
      • Under File Access: File Owner: J-PC; Folder Group: Axis; Everyone: no setting; Folder Owner: R/W; Folder Group: R/W; Axis: R/W; users: RO; guest: RO; J-PC: R/W;
      When I uncheck Allow anonymous access I get a message from Axis Camera Station saying Access to disk has been denied.
      Have I setup the user correctly? What am I missing? Do I need to let it run for a while to see if the new settings have changed something? I would like to remove anonymous access.
      Thanks Again
      • vandermerwe's avatar
        vandermerwe
        Master
        I would start by allowing R/W access to admin, everyone, users, Axis, and J-PC and unticking allow anonymous access.  Does that work?
        As part of figuring this out, what happens if you make the windows user the same as your readynas admin credentials ie  admin/password?
ProSupport for Business
