Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly. First, you will need a Uninterruptable ...
yoh-dah
Nov 25, 2005Guide
cbm wrote: Hi all
I have a ReadyNas X6 on order, what is the expected sustained write performance improvement in turning on write cacheing ? 1 /5 /10 Mbps ?
Or is this feature only available on the ReadyNas 600?
I would like to understand the improvment to see if the increase can justify buying a UPS to enable the functionality (more kit to upset the misses :-( ).
I would like to use the X6 to be the location that my Media Centre PC uses to record TV to - that way it can easily be accessed from other PC's, the throughput of that needs to exceed 4 Mbps sustained.
Kind regards
CBM
Sustained sequential write performance for X6 is about 11-12 MB/sec (megabytes per second) without jumbo frames. With jumbo frames, it can bump up to about 16-17 MB/sec depending on your switch and PC. With the X6, it's highly recommended to run with the write cache enabled. Your performance will suffer a lot if disabled, so do get a UPS. They're actually pretty cheap these days...
