Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly. First, you will need a Uninterruptable ...
yoh-dah
Nov 26, 2005Guide
cbm wrote: Hi, thanks for the update, APC USB UPS on the way.
Out of interest is the sustained write of the ReadyNas 600 similar to the X6 or much higher
CBM
The X6 is faster, by about 2MB/sec.
