Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly. First, you will need a Uninterruptable ...
JReble
Dec 16, 2005Aspirant
I'm only getting about 4.5 MB/sec write speed out of my new X6. I've got a ups with usb port attached, write cache enabled, and I'm using gigabit network cards with a Netgear 5 port Gigabit Ethernet Switch model GS605. Read speeds appear to be satisfactory, but my write speeds are terribly low. What would you suggest?
