Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly. First, you will need a Uninterruptable ...
yoh-dah
Dec 16, 2005Guide
JReble wrote: I'm only getting about 4.5 MB/sec write speed out of my new X6. I've got a ups with usb port attached, write cache enabled, and I'm using gigabit network cards with a Netgear 5 port Gigabit Ethernet Switch model GS605. Read speeds appear to be satisfactory, but my write speeds are terribly low. What would you suggest?
Try disabling the journal. But we do recommend you have a UPS to avoid lengthy filesystem check after powerfail.
