Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly. First, you will need a Uninterruptable ...
yoh-dah
Dec 19, 2005Guide
Please re-run with direct-connect (no need for a cross-over cable). The ReadyNAS will show up as IP 192.168.168.168.
JReble wrote: Ok, ran the tests as indicated....
Write results:
Write IOps: 32.062291
MBps: 8.015573
Transactions Per Second: 32.062291
Avg Response Time: 31.183962
Read Results:
Read IOps: 102.222964
MBps: 25.55574
Transactions per Second: 102.222964
Avg. Response Time: 9.776898
Seems to be writing too slow. :(
