Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly. First, you will need a Uninterruptable ...
JReble
Dec 19, 2005Aspirant
Not using a cross over cable. Using the included patch cable from X6 to ethernet switch, straight through cables from switch to computers.
New Write results:
Write IOps: 29.746077
MBps: 7.436519
Transactions Per Second: 29.746077
Avg Response Time: 33.61286
Read Results:
Read IOps: 106.476407
MBps: 26.619102
Transactions per Second: 106.476407
Avg. Response Time: 9.3866678
I can get considerably faster speeds between my computer and a drive mapped from another computer on the network. The NAS continues to be very slow in the write department.
New Write results:
MBps: 7.436519
Read Results:
MBps: 26.619102
