Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly. First, you will need a Uninterruptable ...
bhoar
Dec 19, 2005Aspirant
JR - Yoh-dah was indicating you should take the switch out of the equation and connect the desktop *directly* to the readynas using a single gigabit ethernet cable.
-brendan
-brendan
