Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly. First, you will need a Uninterruptable ...
yoh-dah
Jan 03, 2006Guide
JReble wrote: Shall I conclude I have a defective unit then? I've got write caching enabled, directly connected and the computer senses a gigabit network connection. Still the same lousy write speeds. Does anyone else use an X6 and get decent write speed?
Please wait for the next beta update. There will be a separate performance option to boost the write speed. ETA hopefully by tomorrow as we're working out some last kinks.
