Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly. First, you will need a Uninterruptable ...
yoh-dah
Mar 29, 2008Guide
kmcgrail wrote:
No, you can turn on write caching without a USB UPS connected.
Thanks for noting this but can you please provide more information about how this can be done? We have our Infrant on a UPS but we do not have a USB connection. I've searched the admin interface without success.
KAM
The USB cable will allow monitoring of the UPS status so the ReadyNAS can shutdown gracefully on batter low. You'll need to use a UPS with a USB connection, and you'll need to use a UPS from our compatibility list -- see http://www.readynas.com/?page_id=76
