Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly. First, you will need a Uninterruptable ...
SuperFlyBoy1
Jan 26, 2009Aspirant
yoh-dah wrote: I would recommend one of the SMC switches in the device compatibility list. The 8505T has been a proven performer. The SMCGS5 and SMCGS8 are new and lower cost, but their performance with IOMeter in sequential access has been indistinguishable with the 8505T. We've seen they can give one or two MB/sec better than other switches in the same price category, and they also supports jumbo frames up to 9K.
Any recommendations for switches in the 24/48 port category with jumbo frames?
We *were* using a Netgear ProSafe GS748TNA, until it's firmware (apparently) caused it to die :shock: :roll: , and we have to now RMA it back to USA... :(
(Edited to Add: I do not see our unit listed in the Hardware Compatibility List, but possibly you want to update your list and also add the No. 3/4 exceptions for this one?? It *is* a Netgear product, btw! ;) )
