Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly. First, you will need a Uninterruptable ...
kmcgrail
Sep 03, 2009Aspirant
yoh-dah wrote:
kmcgrail wrote:
The USB cable will allow monitoring of the UPS status so the ReadyNAS can shutdown gracefully on batter low. You'll need to use a UPS with a USB connection, and you'll need to use a UPS from our compatibility list -- see http://www.readynas.com/?page_id=76
I was wondering if there had been any follow-up on this issue. I had spoken to Support and explained that we are at a collocation facility with UPS/Generator/ATS but no USB connection. I'd like to turn the write-cache on and you cannot plug in UPSes at most collocation facilities.
Unfortunately, that was a long time ago and I'd like to reiterate my request for a manual, root-ssh-required way to enable the write-cache -or- a way to do it in the advanced interface. I'm running 4.2.5 and 4.1.6 across the board.
regards,
KAM
