Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly. First, you will need a Uninterruptable ...
kmcgrail
Sep 30, 2009Aspirant
giblet1973 wrote: Command hdparm -W1 /dev/hdcwill enable write caching.
Great point! Thanks. Will give this a shot!
