Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly. First, you will need a Uninterruptable ...
Lithium-Admin
Jul 01, 2010Novice
drewpc wrote: If I use the ReadyNAS 1000 in a datacenter environment (where all AC power is on a UPS), do I have to have a UPS with a USB connection in order to get write-caching to work?
I also use the ReadyNAS 1000 but is does not seem to work well in my lap. Is there anything wrong with my network? :(
