Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly. First, you will need a Uninterruptable ...
davidr1
Jul 11, 2012Luminary
Hi
Ultra 2
My Left and Right USB ports are connected to USB drives.
Presumably I can't connect a usb hub to a port so presumably that means I can run it off the UPS but not monitor the UPS?
David
Ultra 2
David
