Chewbacca
Jan 14, 2005Aspirant
How to increase write performance on ReadyNAS
You may notice that ReadyNAS may seem a bit slow on writes using the default configuration. There is a way to increase that write performance significantly. First, you will need a Uninterruptable ...
Jul 11, 2012Guru - Experienced User
You should have started your own thread (generally we don't resurrect ancient history).
davidr wrote: Hi
Ultra 2
My Left and Right USB ports are connected to USB drives.
Presumably I can't connect a usb hub to a port so presumably that means I can run it off the UPS but not monitor the UPS?
David
Anyway, the USB hub should work if it is independently powered (http://www.readynas.com/kb/faq/hardware ... s_usb_port)
